Visitor Messages
  • ZOOTECH
    Senior member of CRS
    • 3375
    Post your problem (MX4501) in the Sharp thread, you'll probably get more responses. The trouble is most likely a problem with the primary transfer belt lift. Run TC 6-3 to check belt; it should run between "Black", "Color", and "Free".
    You should be able to hear the rotation of the cam as it executes. Good luck!
