Canon IRC 2030 E000074-0000
  • pcernicky
    • Feb 2010
    • 66
    Hi,
    Got Copier with E000074-000 error code. Check all connections and harnesses, DC controller/PTDS.
    All seems OK!.
    Someone else was trying to fix the copier, now is in error code mode.
    Please help.
    Thank you.
  • zoraldinho
    teacher-guide-expert-guru
    • Mar 2008
    • 5018
    Re: Canon IRC 2030 E000074-0000
    ITB Guide Rail or Transfer Disengagement Solenoid not in the wright place.Also check ITB drive.
    • pcernicky
      • Feb 2010
      • 66
      Does anyone knows part number for ITB Unit for IRC2030 and the price?
      Thank you.
      • Rachid.Akli
        • Oct 2011
        • 595
        Hello,
        FM3-8240-000000 is the ITB part number. Sorry, i don't have the price.
        Rachid.
        "Find a job you love and you’ll never have to work a day in your life." Nagy's father
        • pcernicky
          • Feb 2010
          • 66
          The color copy quality is really bad, color is off and light horizontal lines, check the sky-shot on the black drum and it's grey not solid black plus i see 2 inch void area around drum.The drum unit is brand new.
          Just want to confirm that the issue is ITB unit.
          Copier has 10k copies, but it wasn't working right for couple months and also some other guy was playing here with the copier.
          Thank you for advice.
          • teckat
            • 16083
            Is the tech trained on this Advanced series model ????
            some techs think they can just walk up and repair anything that prints
            E074 is an Error in the Primary Transfer Disengagement Control.
            Check SW1 ( Primary Transfer Disengagement Switch) for Displacement
            • pcernicky
              • Feb 2010
              • 66
              It was the switch , the error code is gone, but I need to confirm the copy quality issue.
              Thank you.
              • teckat
                • 16083
                Thank you.
                if u still have a CQ issue/ post some copies of them/
                also post some TEST PRINTS
                • Rachid.Akli
                  • Oct 2011
                  • 595
                  Hi,
                  This model has black CQ issue. Most of the time, it doesn't display any message when the black toner bottle is empty. This will lead to a lack off black toner on the dev cylinder and ends up with a low density or an error code (E020). I advise you to to verify the black toner bottle content and the black density on Display> Dens > SGNL-K. In normal conditions , it's arround "0". If it isn't the case, you can execute a toner supply, switch "off" and "on". Do it until the toner SGNL-K recovers its normal value (arround 0).
                  If the black CQ is recurrent, replace the black toner hoper with the new part number: FM3-8084-010000
                  Replacing the Black drum is not the solution.
                  Rachid.
                  • sx633
                    • Sep 2011
                    • 49
                    Is that the tiny little black microswitch behind the main drive assembly ?
                    • teckat
                      • 16083
                      YES
                      At the primary transfer disengagement control, the sensor fails to detect although the specified time has passed (the
                      specified time differs depending on the mode)
                      Error in the Primary Transfer Disengagement Solenoid, Error in the Primary Transfer Disengagement Switch, or the ITB
                      Guide Rail error.
                      1. Replace the ITB Unit
                      2. Check the harness/connector between the DC Controller
                      PCB (UN09/J11) and the Primary Transfer Disengagement
                      Switch (SW01)
                      3. Check the harness/connector between the DC Controller
                      Solenoid (SL01)
                      4. Check conduction of FU6 on the DC Controller PCB (UN09)
                      5. Replace the ITB Guide Rail
                      6. Replace the Main Drive
                      7. Replace the Fixing Drive
                      8. Replace the DC Controller PCB (UN09)
                      • sx633
                        • Sep 2011
                        • 49
                        Thought so, I discovered that today.
                        E020-0191, colleague ordered main drive assembly, which I fitted (and refitted numerous times) and now can't clear E074.
                        Got DC cont' and fuser drive assembly on order now.
                        • teckat
                          • 16083
                          there are a mass amount of connectors to check/
                          also u need to follow the re-positioning procedure > or u will have error codes ?????????????????
                          i will try and post a video later
                          • godyng
                            • Dec 2008
                            • 40
                            Is the video has been posted ???
                            • teckat
                              • 16083
                              image RUNNER ADVANCE C2020 / C2030
                              How to replace the Main Drive Assembly
