View Full Version : Bizhub C35 fax to folder
bobe
07-24-2012, 02:29 AM
Hello,
There is an option to send a fax to folder or to BOX. I setup scan to SMB but I don't have Box option. Customer wants all the faxes to be saved on HDD. Who done it maybe can help me This copier has the PC-fax option and the fax can be saved in the machine memory.
Mr Spock
07-24-2012, 04:11 AM
This machine does not have user box option.
Gort
07-24-2012, 06:24 AM
If the scan to HDD is unavailable the HDD is not set up properly or has failed. I have had a few HDDs on the C35 go south and had to reinitialize them.
Description:
How to scan a document to the Hard Disk Drive (HDD).
Solution:
To scan a document to the Hard Disk Drive:
1. Place the original document into the document feeder or place it on the glass.
2. Press the Scan-to-Folder key.
3. Press the Direct Input key.
4. Press the HDD key.
5. Press Save Document.
6. Press Document Name and press the C key to clear the field. Using the keypad, type in the name of the document and press OK.
7. Press the Public key to allow use by any operator.
