Bizhub C35 fax to folder
  • bobe
    • Oct 2011
    • 38
    Hello,
    There is an option to send a fax to folder or to BOX. I setup scan to SMB but I don't have Box option. Customer wants all the faxes to be saved on HDD. Who done it maybe can help me This copier has the PC-fax option and the fax can be saved in the machine memory.
  • Mr Spock
    Vulcan Inventor of Death
    • Aug 2006
    • 2064
    Re: Bizhub C35 fax to folder
    This machine does not have user box option.
    • Gort
      Copier Demon
      • Oct 2011
      • 50
      If the scan to HDD is unavailable the HDD is not set up properly or has failed. I have had a few HDDs on the C35 go south and had to reinitialize them.
      Description:
      How to scan a document to the Hard Disk Drive (HDD).
      Solution:
      To scan a document to the Hard Disk Drive:
      1. Place the original document into the document feeder or place it on the glass.
      2. Press the Scan-to-Folder key.
      3. Press the Direct Input key.
      4. Press the HDD key.
      5. Press Save Document.
      6. Press Document Name and press the C key to clear the field. Using the keypad, type in the name of the document and press OK.
      7. Press the Public key to allow use by any operator.
      Sorry, I do not have a cat in my avatar.
