Toner for ARM450
  • sundakib
    • May 2010
    • 23
    [Misc] Toner for ARM450
    We have supplied several ARM450 series machines to several regions.Is it possible to use AR450FT in place of AR450ST.What is the difference between
    that two toners.Is there any settings is available for that to use ARM450FT toner.Kindly advice me.
    • 23010
    Re: Toner for ARM450
    From what I can tell, both are compatible with the Tiger series.
    For me, I'd avoid compatible toner cartridges.=^..^=
    • igi
      • 1507
      hi the toners are desighned to work for diferent parts of the world
      ie diferent destinations,if yours got ic(CRUM-CHIP)THEN diferent toner will not work
      good luck
      • lky1978
        • Mar 2009
        • 483
        possible f2-04 occur
        • Dark Helmet
          • May 2009
          • 865
          You could try going into sim 26-6 and tell the machine it lives in a differnt part of the world that the toner is supposed to be for. Not sure what the negative effects would be though. I know with fax kits if you change the destination set they won't work in your country as every body's phone system is differnt. Maybe process control will react differnt.
          Evil will always triumph because good is dumb.
