Af 2060 display
  • Butrus
    • Jan 2012
    • 115
    Af 2060 display
    The machine works perfectly.
    Only thing is that while copying,display dims black.
    Display works good othervise.
    Its like while fuser is on,display lacks voltage or something....
  • neergish
    • 177
    Re: Af 2060 display
    Sounds like tiny fluro lamp in your LCD display (part no B1881435) is about to give up the ghost. I've seen this a couple of times, i would be replacing that first to see if the proble still occurs. The next modles (MP5500-MP6000) along included a inverter but ive seen the LCDs go of these as well.
    "See if you can rent a spring hook and a phillips screwdriver it will make your life that much easier..."
    • Butrus
      • Jan 2012
      • 115
      Re: Af 2060 display
      I will try that thanx!
        • 37444
        Re: Af 2060 display
        You might also want to monitor the line voltage coming into the machine. Low line voltage can cause all sorts of problems.
        • Iowatech
          Not a service manager
          • 3930
          Re: Af 2060 display
          There might be a knob on the left hand side of the op panel that if you rotate it clockwise might brighten up the display.
          • Butrus
            • Jan 2012
            • 115
            Re: Af 2060 display
            No shit?
            Display is lit up OK
            When you make copys it darkens.And is OK again when job ends.
            I can make it readable if I turn the knob while copying is in progress
            But afterwards is all white...
            • joshuadenmark
              Re: Af 2060 display
              Can't really see this as a problem, who wants to look on a copiers display when copying?
              • Hansoon
                • Sep 2007
                • 3380
                Re: Af 2060 display
                No shit?
                *dislike*
                Colleague is just trying to help. No need to be sarcastic.
                Hans
                “Sent from my Intel 80286 using MS-DOS 2.0”
                • Butrus
                  • Jan 2012
                  • 115
                  Re: Af 2060 display
                  Thanx for deleting my rep points over this!
                  I didnt see that post as help,sorry!
                  It was sarcasm from him!
                  There MIGHT be a knob?
                  That MIGHT do what?
                  And you delete my Rep Power ?
                  Wow!
                  Best regards!
