MAC scanning
  • logrady2331
    • Feb 2011
    • 301
    MAC scanning
    Heelo all,
    I'm sure this has been addressed before but I'm unable to find any posts about it. I have a customer with a MAC, O/S version is 10.9. He wants to scan to folder. Are there any white papers/step by step instructions for a Ricoh MP C2050? I think FTP is easier but have never set up scan to FTP either. Any help would be greatly appreciated.
  • ruben
    The New Guy
    • Oct 2012
    • 1203
    Re: MAC scanning
    Currently only 10.8 or below is supported with SMB scanning (NIB firmware v8.33 and System/Copy firmware v1.20, and above). There is no news on any SMB support for 10.9 and above.
    Setup FTP on mac: http://www.macinstruct.com/node/152
    Then setup the scan on the copier as you normally would.
    • logrady2331
      • Feb 2011
      • 301
      Re: MAC scanning
      Thank you sir!!
      • rthonpm
        • Aug 2007
        • 2854
        Re: MAC scanning
        You'll want to advise any Mac customers that all OS upgrades will cause issues like this. I've been lucky for the most part with getting some of my customers to keep their machines at a level their devices will support. Sadly, that's not always the case.
        • ApeosMan
          • Nov 2009
          • 183
          Re: MAC scanning
          FTP is the way to go on Mac's. Some newer MFP devices now support the SMBX which is Apples new SMB protocol that was introduced in 10.7 from memory. But Apple will most likely screw things up again with future updates
          Long live the IBM compatible PC!
            • 37493
            Re: MAC scanning
            Micorsoft screwed scan to SMB with both win7 and win 8. All MFP manufactors had to come up with firmware solutions to compensate.
            • pic-nic
              • Sep 2012
              • 11
              Re: MAC scanning
              The SMB 2.x protocol was introduced in Windows Server 2008 and in Windows Vista.
              The SMB 3.0 protocol was introduced in Windows Server 2012 and in Windows 8.
              Microsoft decided moving forward to default Win8/Server2012 to utilize SMB3.
              Moving forward
              Solid Decision
              Ricoh: Has had issues with SMB3, since they are always behind when it comes to advances.
              Konica Minolta: No issues that I am aware of with SMB3
              Kyocera Mita: No issues that I am aware of with SMB3
                • 37493
                Re: MAC scanning
                Moving forward
                Microsoft also told the industry that SMB 3 would be 100% reverse compatible with SMB2 devices.
                • wseyller
                  • Sep 2012
                  • 1129
                  It is hard to set up scanning on a Mac unless it is 10.6 or lower at least in my experience. I normally recommend to just scan to a shared folder on a different device or just scan to email.
                  Sent from my DROID BIONIC using Tapatalk
                  • webfoot
                    • Jan 2013
                    • 4
                    Re: MAC scanning
                    Another workaround we do is to have the customer scan to the copier's document server. Then access and download the document through the WIM.
                    • bronco31
                      • Aug 2009
                      • 174
                      Re: MAC scanning
                      hmmm.. can you give details?
                      • redneckstylin
                        • Sep 2011
                        • 173
                        Re: MAC scanning
                        offtopic ...I hate macs paired with ricohs
                        • qbert69
                          • Mar 2013
                          • 1152
                          Re: MAC scanning
                          Originally posted by logrady2331
                          Heelo all,
                          THIS ISSUE HAS BEEN ADDRESSED!!!...SEE POST #5 AT THIS LINK REGARDING SCAN TO SMB/CIFS!!!
                          http://www.copytechnet.com/forums/ky...up-mac-pc.html
                          SEE POST #5!
                          CHEERS!
                          REACH FOR THE STARS!!!
                          Konica Minolta Planetariums!
