Kyocera KM4050 reset command centre login
  • xman
    • Aug 2010
    • 48
    Cannot access command centre. I suspect someone has changed the user name and password.
    I have tried the default user: admin. Password: admin00 or admin01. But no go.
    Can anyone help initialize the user and password ?
    • 22999
    Re: Kyocera KM4050 reset command centre login
    There never was a default login. The default is no login or password. See this link:
    http://www.copytechnet.com/forums/ky...km-c3232e.html
    • openroad
      • Sep 2011
      • 7
      How do I enter the commands on a Kyocera 400ci. We have lost the command center password and just want to reset to something.
        • 22999
        Have you tried the default username and password? If it has been changed you can use exactly the same procedure in the link. =^..^=
        • openroad
          • Sep 2011
          • 7
          When I log into command center at 192.XXX.XXX.XXX my command center only has a password to "input the password" with no user name. I have tried every password in the previous threads (admin00, admin01, password, "blank","", 4000,etc) The machine user name and password are 4000/4000. Where do I enter the command ?
          !R! ACNT "REST";EXIT;
          Is it on the machine or somewhere in the command center to change the command center password for the 400ci?
          thanks for your help.
          • kyocera.team
            • Aug 2010
            • 126
            its prescribe language the easy way to do that is
            first of all you should use KX driver
            -printer properties
            -device setting
            -PDL (use PCL5e )
            then open new word file and select prescribe font and type
            !R! ACNT "REST";EXIT; this for reset the job account password
            and
            !R! EGRE; EXIT; this is for command center
            it will solve your problem good luck
              • 22999
              I don't think that any of the Wisecore machines still have the Printable Data link in Command Center any more. The last machines that still had it were the CS-8030 and CS-C4035E.
              There are many ways that you can send the PreScribe Command to the MFP: Command Line, Printable Data, KM-Net Viewer, IC Link, but the simplest is LPR Jar: GCC File Send Utility
              Just write the command in a Notepad file and save.
              Load LPR Jar.
              Open LPR Jar.
              Enter IP address of recipient printer.
              Browse to the command file.
              Send.
              Easy as cake.
              This is the 43rd posting on this topic, per the search engine. =^..^=
              • openroad
                • Sep 2011
                • 7
                You've been awesome. downloaded utility, created wordpad file, started jar, loaded printer ip and hit 'Send File' and it waits for a few seconds but says 'Connection refused: connect'. Its the correct IP address because I copied right off by command center page. Something about the printer is not letting the utility on. Even when I hit 'Printer Status' on the LPR utility is gives the same error message. I can print to the printer with no problem.
                Any ideas why the utility can't connect?
                  I have always used DOS to reset these things
                  open notepad and copy paste the following
                  save the file as reset.txt
                  Open cmd and cd to the directory where you saved reset.txt and in the cmd prompt type the following
                  ftp ***.***.***.***
                  ***.***.***.*** = ip address of printer
                  Next press the enter key twice (no password required)
                  Next type put reset.txt and press enter
                  • openroad
                    • Sep 2011
                    • 7
                    This was easy and it uploaded but it didn't change the password to blank. The subject heading say Kyocera KM 4050 but its a 400ci that I am trying to reset the password. Would the commands change in the txt file?
                      ok try
                      !R! EGRE;"REST" EXIT;
                      or this
                      !R! EGRE"REST"; EXIT;
                      • openroad
                        • Sep 2011
                        • 7
                        Still no luck. I am about to punt this machine. I can clearly see the file gets transferred and I copied the language directly from your post.
                          • 22999
                          The command is the same regardless of the machine model. Ordinarily I would not suggest this because it's a lot of work and risk, but here goes:
                          Print off the U000 maintenance report. You'll need it.
                          Note any Scanner data. It's about to disappear.
                          Backup any job accounts in U917.
                          Here's the scary part:
                          Perform a U020 Memory All Clear.
                          Now to restore all the stuff you just erased:
                          Reset U265 Destination to 02 (for KM) or 66 (for CS)
                          Reload firmware currently version 12.00/1.13
                          Re-enter as much of the Maintenance report data manually as possible.
                          Re-enter scanner setup data.
                          Import job accounting ID data.
                          Perform color calibration.
                          There's two hours work here. Just be sure to backup as much as possible before-hand. =^..^=
