I have IR 6570 with touchscreen not responding. You can go to service mode but cannot use touchscreen to navigate as it does not respond to anything. Any known fix for this? Thank
problem with IR 6570 in touch screen
Tags: None
Re: problem with IR 6570 in touch screen
if you have trouble with Analog touch panel (glass), coordinate of button will misplaced (shifted), you just need to clean itLearning never ends..
Never give up, where there is a wheel there is a way..
yea the surface of analog touch panel...Learning never ends..
Cleaning the contacts of the lcd. dust can cause bad contact in the display and the touch fault.Comment
leocastell
