problem with IR 6570 in touch screen
  • bluesky2000
    • 95
    I have IR 6570 with touchscreen not responding. You can go to service mode but cannot use touchscreen to navigate as it does not respond to anything. Any known fix for this? Thank
    Re: problem with IR 6570 in touch screen
    Yes replace the touch screen.
    FK2-0246-000 - ANALOG TOUCH PANEL UNIT
    • jiongpao
      • May 2009
      • 413
      I got a same problem on ir8070 but im wondering if we only change the touch screen glass not a LCD screen will it work?
      • vigour
        • Aug 2010
        • 1038
        Lcd screen is FL2-1092
        Touch panel sits on top of LCD.
        3 people gave you the touch panel part number.
        take it apart and you will see.
        • arielcanon
          • Mar 2012
          • 106
          if you have trouble with Analog touch panel (glass), coordinate of button will misplaced (shifted), you just need to clean it
          Learning never ends..
          Never give up, where there is a wheel there is a way..
          • Matoku
            • 173
            Ariel, What do you mean by cleans the touch screen? either on top of it or ealse?
            • arielcanon
              • Mar 2012
              • 106
              yea the surface of analog touch panel...
              • HELIO240
                • Jan 2011
                • 137
                Cleaning the contacts of the lcd. dust can cause bad contact in the display and the touch fault.
                • leocastell
                  I have the same problem bluesky2000, but the machine is an iR5570, you have solved anything so far? would appreciate your comments if you already resolved.
