Kyocera: New High-Performance Module with 215 Watts and 14.4% Efficiency
This topic is closed.
  • RSS Robot
    I post the news
    • 2595
    The Japanese technology corporation Kyocera, one of the leading manufacturers in the photovoltaic field, is bringing a new solar module from the successful KD series onto the market. With its high nominal output, extreme stability under mechanical pressure and optimized junction box, the new KD215GH-2PU fulfils high requirements in every field.The KD215GH-2PU high-performance module achieves a nominal output of 215 watts at an efficiency of 14.4 per cent under standard test conditions. Compared with the predecessor model, the KD210GH-2PU, Kyocera has again been able to improve the cells, while retaining the same module size, and increase output by 5*watts. The
    More...
