Best Brand of Copier
THE ONLY THING FOR EVIL TO TRIUMPH IS FOR GOOD MEN TO DO NOTHING..........edmund burkeComment
Re: Best Brand of Copier
I am new to Sharp. I like them, but they EAT PARTS. Nearly half my calls require a PM, which requires me to drive an 18 wheeler full of parts.
And I dont like that their part numbers are all random. Some 7 digits, some 13 digits, some with dashes, zeros mixed with O's.
And I don't like their sensor names, not very intuitive, A registration switch should be called a registration switch not SPPD2, CPDLR1 or whatever. I have to keep looking up what's what.
But for the most part everything comes apart pretty easy. Not a lot of hidden screws and teardowns.Comment
They are? Aw.
In the analog days there were some Lanier branded Panasonics out in my part of the periphery, and after I got used to them (Laniers were primarily rebadged Toshibas at the time) I thought they were OK.Comment
Consumable parts have shorter ITEM#'s
Repair parts have 13 digit PART#'s
You can know a lot from just looking at them after some practice.
Oh and about the 0's and O's, All the 0's have slashes through them on the Part#'s. Just put slashes when you write it down, to help with that confusion.Comment
Well, I don't mean that Kyo or KM manuals are bad but Brother has a lot of detailed sections including gear layouts, lubrication points, harness routing diagrams, disassembly flowcharts, switch settings, etc. I was seriously impressed by the amount of useful information. Not only that, but they're super intuitive. Error codes or (dis)assembly references will link to their references 95% of the time.WhateverComment
For B/W copying is only best RICOH, because, have faster scanner. It's easy to slove the problem, because have SC code.
For B/W and Color printing, KONICA MINOLTA... You can print whole pages, and you can change details in fiery...Comment
I'll take a Kyocera over a Ricoh ANY DAY!
Why?
Kyocera actually serializes the Fusers AND Photo Conductor units on their large machines and small machines...since you replace instead of rebuild. If a serialized unit fails before it's end of life, it is warrantied and Kyocera wants to know WHY!....they will most often take it back and send you a new one!...they build a database of failed units--serial numbers which are tied to production dates, lot numbers, yadda yadda, etc. Kyocera CARES!
Ricoh on the other hand, doesn't give a S#!t....not their damn fault!....it's the tech's!
Kyocera's Research & Design is alot better than Ricoh's!
Kyocera makes an Amorphous Silicon imaging drum, 98% the hardness of a diamond and 6 times the life of Ricoh's S#itty Organic Photo Conductor!...1 visit of 30 minutes replace and reset (6x the copies of an OPC drum) vs Ricoh's having to visit 6+ times to rebuild, replace and/or clean the PCU's.
a-Si Photoreceptor | a-Si Photoreceptor Drums | Printing Devices | Products | Kyocera
Ricoh uses crappy foam (think dry rot) for their finisher gathering rollers and whatnot. Kyocera uses rubber mostly for there finisher rollers. On mid size B&W models developer (developer separate from toner) units epicly fail, dump developer down into the paper feed units, thus requiring a good half day to fix everything--cleaning and lubricating. Kyocera on the other hand uses mono toner developer and toner together--works great!--with always a fresh flow going thru the developing unit, therefore minimizing contamination!
Kyocera innovates more than Ricoh--it's easily obvious!....I just wonder when it's gonna catch up with Ricoh!...as I say, Ricoh puts lipstick on their pig....same mechanics and machine underneath except for the exterior and engine which changes.
Ricoh says it is environmentally friendly, but when the math is done requiring 6x the amount of visits and materials, Ricoh is full of BULLS#!T.
Need I say more?
REACH FOR THE STARS!!!
Konica Minolta Planetariums!
https://www.konicaminolta.com/planet...gma/index.htmlComment
Canon hands down. Kyocera has decent drums and dev units, but everything else is too finicky.
Canon actually uses drums made by Kyocera. They have decent tech support, and go forever with not many problems
Sent from my SM-G920V using TapatalkComment
