lube
    Re: lube
    Originally posted by nhyrum
    But... Did it stop squeaking?
    Sent from my SM-G920V using Tapatalk
    it MIGHT stop the squeaks .. but it wilL MUCK up the damn unit. It melts plastic.. it will destroy the clutches and if it drips on a board.. it will fry it. Brass bushings it will dry them out.
    • Mark Bbb
      • Jun 2012
      • 1662
      #17
      Re: lube
      So, by better stuff and when you still use WD-40, give it to your mother in law !!!
      • nhyrum
        • May 2016
        • 55
        #18
        Re: lube
        Not saying you use wd40. Just being a little sarcastic. If it stopped the squeak, s'all good! Small price to pay to replace a few clutches and a DC controller
        • TheBlueOrleans
          • Aug 2012
          • 232
          #19
          Re: lube
          Maybe someone can tell me what the hell I'm supposed to use this "drysurf" on, since I have to shake the bottle once a week to separate it anyway, I might as well use it. There's a technical bulletin about it, I'm certain of that, just not certain how to find it. For having damn near all the technical information about the products available on the website, you'd think it would be easier to navigate.
          Somewhere there is a tree working hard to produce oxygen for you to live, NOW GO APOLOGIZE TO IT!
          • vincent64
            • 382
            #20
            Re: lube
            I have found this lube to be pretty good stuff...
            and they make it in a spray also...
            it is a synthetic type of lube, made right here in the good ol' USA, in Big "D"..Dallas to ya'll non Texans
              • 14813
              #21
              Re: lube
              It was initially sent out to lubricate the fusers on the C452 I think. I don't have any C452s so I use it for other things. I had a car window that was very slow going up and down, so, I squirted some Drysurf between the glass and frame and it worked great. Window now goes up and down smoothly. That was in the summer and still working. Seems to be good stuff.
              • Iowatech
                Not a service manager
                • 3930
                #22
                Re: lube
                Originally posted by Mark Bbb
                Blackcat: thank you, but none of the products are available in Belgium, Germany or Netherlands.
                Anyone knows?
                Does DuPont do business there? Their Krytox line of lubricants work well.
                Also, we used SuperLube oiler pens successfully in some applications, and the one time I pulled the label off of one of them the default printing on the body of the thing appeared to be in German. But I only took three semesters of German language classes in high school back in the '70s and haven't spoken more than a couple of sentences of that language since, so I'm probably wrong there.
                • nhyrum
                  • May 2016
                  • 55
                  #23
                  Re: lube
                  I'm sure they do, they're a big enough company.
                  I will say... It's not cheap. But it is DuPont
