Medical Field Service Engineer?
  • xeclectron
    • Sep 2016
    • 10
    Hi all,
    I've heard of a few occasions where MFD Engineers have made the jump into the medical world, and I've been trying to do some research into it...except I can barely find any information about it online, there doesn't seem to be a forum like copytechnet for that particular industry to find out what it's like.
    Anyone know of people that have made the jump? Can you just walk into the role with years of copier experience and manufacturer training behind your belt or is it not that simple? What are the similarities and differences between copiers and medical engineering on a day to day basis in the UK?
    Many thanks
    • 37447
    Re: Medical Field Service Engineer?
    The company I worked had another copier tech years ago who decided to become a respiratory technician, the field that his wife was in.
    • joeh
      • 21
      • mikadonovan
        • May 2008
        • 2931
        Years ago a couple of guys left the company to work on ATMs and retail scanners, the transition was smooth.
        NEVER ASSUME ANYTHING
        • joeh
          • 21
            • 8178
            In the recent past, Toshiba had in my territory six medical techs and one service manager who primarily serviced multi-million $ CT imaging machines, other imaging machines and annual service contracts.
            It was not uncommon to send a tech to Japan for two weeks and spend upwards of $250k over time to get that tech trained to a very high standard.
            You will be on call 24/7 and have to cover a large territory. It may not be the territory in which you currently reside. You will be well paid and have a life long stable career.
            As the demands for healthcare hardware technology can only increase, so do the opportunities.
            No one ever died from a copier that did not work properly and on time but someone can die if a CT machine images a blood vessel two mm off where it is suppose to be.
            You need to get a job servicing medical equipment in a healthcare center with a few years experience before you will be considered to be hired on by a national vendor.
            Another good opportunity is as a solar panel or wind turbine engineer.
            • havokprod
              • Oct 2012
              • 159
              Is he or she doing ok/well for themselves?
                • 8178
                To be an ATM/ Scanner tech is no better financially than a copier tech except you are on call 24/7.
                I have worked with a few dealers where the copier techs were cross trained on ATMs. You will drive a lot of km/ miles in all weather. Eventually the copier dealers gave up the ATM business because the techs did not want to drive that much especially in the winter.
                • clint@clintsimonsen.com
                  • 124
                  When working for Toshiba eid direct, we had a relationship with the other divisions and had a few techs move business groups. But in the last few years I've had a few friends start working with a dental equipment firm one got a job then got 2 more in. Interesting work a bit more travel, not a huge amount more money but better. Just have to work with dentists
                  Sent from my ONEPLUS A6000 using Tapatalk
                  • mikadonovan
                    • May 2008
                    • 2931
                    All was good the last time I spoke with them.
                    • Hansen88
                      • 1065
                      About the wind turbine engineer,I saw a television show and they showed a guy who was doing a final in the field test to see if he would get the job. The two biggest things it takes to be in that field is that you have to carry your tools and parts up spiral staircase all the way to the top,no elevators in those things. So just to be able to do that is the first step. Then the next big one is getting harnessed up and going out on top and moving around out there. They figure if you can do those two things they can teach you the rest.
