White Privilege, clear cut.
    • 37446
    #241
    Re: White Privilege, clear cut.
    A lot of folks on here mention a copier company being sued for this or that, but I've never actually heard of one being sued for network security. If I google it, nothing comes up. Common sense tells me that it's not nearly as simple as some make it out to be to hold a copier company liable.
    If HP (or pick a company) releases software that is vulnerable, can I sue them? I doubt it.
    With a properly configured on the router connecting you to the internet, the ports used by all SMB versions can be closed to any and all unwanted external internet traffic. That would mean that any bad actor attempting to exploit the SMBv1 vulnerability would have to already be inside your local network. If that is the case you have lot more problems than the SMBv1 vulnerability. In addition, you can configure security on a Server 2019 to only allow access to ports and services, SMB is a service, to specific devices on the network by IP address and MAC. If the MFP is the only thing allowed to use SMBv1, no problem.
      • 30091
      #242
      You're getting desperate. You're down to posting links about improperly disposing of hard drives that contain personal medical records.
      Proves the point Rookie
      Hey your a client's wetdream just a matter of time
        • 30091
        #243
        Another non IT rookie
          • 16374
          #244
          There are people on this site that are true IT professionals. And then there's you. The faker. When an IT conversation moves past the very basics, you disappear in a hurry.
            • 30091
            #245
            End of your School today Yes u FAILED
              • 16374
              #246
              PS - I've never see a man try so hard to prove that he's an IT professional. It's smells of desperation. What's really sad is that you get upset when I try to learn from someone. Does that threaten you, little man?
                • 30091
                #247
                Considering you CAN'T add toner in a machine and have no factory training.
                Unfortunately your a Rookie who thinks he knows it all
                When you want help just ask me. Your Welcome
                  • 16374
                  #248
                  Unfortunately you a Rookie know it all
                  Sure, okay, I need some help. Here's the scenario. I'm trying to get DCHP to work across a WAN but for some reason DHCP can't cross a router and thus any device on the other side of said router doesn't receive a DHCP address. Why is this happening and how do I fix it?
                    • 30091
                    #249
                    Sure, okay, I need some help. Here's the scenario. I'm trying to get DCHP to work across a WAN but for some reason DHCP can't cross a router and thus any device on the other side of said router can't receive a DHCP address. Why is this happening and how to I fix it?
                    Google or watch a YouTube I am sure thats what you do all day long
                    Plug it in first Hilarious
                      • 16374
                      #250
                      I already know the answer.
                        • 30091
                        #251
                          • 37446
                          #252
                          For as long as I can remember, Ricoh's published policy for any machine that did not have Disk Overwrite Security was to ask the customer if they wished to have the HDD from their machine so their IT could properly clear any data left on it.
                            • 16374
                            #253
                            What I try to do is learn all day long from anyone and everyone. That's a sign of intelligence. Only a fool thinks they know it all. Hello fool.
                            Getting back to why DHCP can't cross a router.....
                            Have your ever heard of DORA?
                            It's stands for
                            D.iscover
                            O.ffer
                            R.equest
                            A.cknowlegement
                            Once you understand that, you'll know why DHCP can't cross a router and then you can learn how to solve the problem. If you ask nicely, I'll tell you how.
                              • 30091
                              #254
                              Have you heard of ohms law?
                                • 30091
                                #255
                                Do you know the copy process?
