looking
  • tcypy1961
    • 773
    looking
    I have a customer looking for printer or copier(color preferable) that has a minimum of 3 separate pf sources. One of those pf sources is wanted for 12x18 paper. Is there a printer or copier out there like such??? I did a google search and found nothing.
    Thanks!!!
  • JR2ALTA
    • Feb 2010
    • 2030
    Re: looking
    Thanks!!!
    No printer that I know of..that's why we're still servicing HP5500s!
    • tcypy1961
      • 773
      Re: looking
      will they do as customer is looking for???
        • 8144
        Re: looking
        Thanks!!!
        No problem! New, Toshiba eStudio 2515AC series/ used e2505AC series. Used is a hot box, so impossible to find. Like every OEM, deep back orders with 30-60 day delays are not uncommon on new.
        I have sold several just because of this feature to engineering firms, construction firms any business that works with drawings or blueprints.
        Wide format printers print drawings on 24" x 36" paper. This is known as full "D"size.
        12" x 18" is known as "half D" size and scales perfectly.
        If you are not a Toshiba authorized dealer, you will never get one, nor toner nor parts, nor technical support. Best hope is to partner with an authorized dealer, get a built in one time sales commission and you are done.
          • 37362
          Re: looking
          There are numerous MFP and printers that come with 1 tray plus manual feed table that use add-on trays that stack under the main device. I have seen HP with up to 5 trays.
          • JR2ALTA
            • Feb 2010
            • 2030
            Re: looking
            HP 5500 are older than dirty and not currently in production but they were a rare color printer that could handle Ledger (up to 18"). Sales reps had a hard time replacing them.. Of course if MFPs are an option that makes it a lot easier for you.
            • tsbservice
              Field tech
              • 7977
              Re: looking
              Why not MFP? Author asked for printer or copier
              • spanky
                • Sep 2012
                • 468
                Re: looking
                All of the A3 Sharp copiers that have been produced in the last 4 years will feed 12 X 18 paper
                • JR2ALTA
                  • Feb 2010
                  • 2030
                  Re: looking
                  Yeah I know. I was just shop-talking about how rare 18x12 printers are.
                    • 37362
                    Re: looking
                    With Ricoh MFP at least until I retired, other than entry level models they could handle 12X18 SEF out of their paper trays 2-4 and the bypass table. So if all the customer is interested in is printing, no problem.
