$5.00 per gallon gas
    • 37508
    #976
    Re: $5.00 per gallon gas
    Depending on where you live the price at the pump may have gone down in the last couple of months, but not due to anything that the current administration has done. The higher priced summer blend required by the Clean air Act in most of the country is no longer required by the federal government every year after September 15th. For some states like California it will continue to be required until the end date set by the individual state.
      Man Plugs $80k+ Electric Truck Into His House, Finds Out It Will Take Over 4 Days to Charge
        • 37508
        #978
        That is because most home electrical systems cannot 150 to 350 KW needed for Level 3 charging. Most home service entry panels are either 60 Amp or 100 Amp per leg. That is at most 2.4 KW for a a 240 volt connection. If you want Level 3 charging at home you will first need to find some who will sell you a Level 3 charging station compatible with your EV and then purchase a 350 to 500 KW 24 Volt DC diesel generator. One thing to remember when using a Level 3 charging station, if you try to charge to more than 80% you run the risk of overheating the lithium battery, causing it to explode.
          • 14754
          #979
          The only people who claim leaders have any bearing on gas prices are you righties.
            Man Spends $71,000 on Solar Panels - Gets $500 Bill Per Month Plus He Can't Use Them
              • 30248
              #981
              2.79 for gas
                2.79 for gas
                Not in the rest of the country.
                Good job Ron.
                  • 30248
                  #983
                  Good job Ron.
                  Great job Joe Biden
                  Maybe its from all the Oil refinery and oil wells in Florida.
                  Yep Florida the Oil capital of THE World
                    • 37508
                    #984
                    2.79 for gas
                    In Florida thanks to your Conservative Republican governor. I see you read the prices I posted the other day. National average is $1.00 more at $3.796. "An 11-day streak of increases to the national average price totaling 12.6 cents ended with a decrease of four-tenths of a cent to $3.796" Average Price of a Gallon of Gas in LA County Nears Record – NBC Los Angeles
                      • 37508
                      #985
                      Great job Joe Biden
                      So you are admitting that your Conservative Republican governor is doing everything that can be done to keep production costs down thereby keeping the price at the pump affordable. Even after Ian came through.
                        • 30248
                        #986
                        Yes Florida filled with Oil Fields and Wind Mills
                        Florida the Oil Capital of the World
                          Oh no!
                          You got him there..
                          RD has always been an AH before.
                            Um. Not really but nice deluded try.
                              • 37508
                              #989
                              OPEC: Oil prices could soon return to $100 a barrel, analysts say
                                • 30248
                                #990
                                See the Republicans plan below
