Do you have a copier at home?
  • NeoMatrix
    Senior Tech.
    • 3514
    #106
    Re: Do you have a copier at home?
    old post... I'll bite...
    Yeah, I have few working non-working copiers and printers at home...
    Most of them are working intermittent, eg. low on toner, need fuser roller etc.
    I find myself getting annoyed every time someone want a quick print out or copy.
    They come around to my place an I have to do IT or Tech work to get one going.
    Which is a bit of a bummer, it reminds me of something called work.....
    • gneebore
      • Feb 2010
      • 555
      #107
      Well at least they don't ask you to go to their house and take a quick look at their machines there. The neighborhood a while back found out I worked on office equipment courtesy of the signs I had to put on my car. They finally quit when i started charging handing a bill from where I worked. Told my boss I was doing that to get them to stop bugging me and he said okay.
      • larweedad
        • 92
        #108
        I had a Minolta 2151. Using toner from a 5400. Tossed the copier after several years and the drum and cleaning blade went bad, I think that was about 10 years ago or less.
          • 8144
          #109
          If you work from a Home Office, you need a current copier to keep up with all that happens in the industry all of the time.
          New firmware, new apps, new print drivers, TeamViewer, OSX, software solutions, A3/A4 operating systems.
          Most techs these days are expected to do more than break/fix.
          If you are responsible for multi brands, you might need multi copiers at home.
          In this industry if you are not learning all of the time, you income opportunities decrease very day.
          • nhyrum
            • May 2016
            • 55
            #110
            I've got a brother MFP-L8850CDW. It was a device that was traded in and headed to the trash heap. All I wanted was a laser color device, because I rarely print at home, and id get one print out of ink jets then I wouldn't use it for a while and it would dry up.
            My boss refuses to have anything printer related at his house.
            Sent from my SM-G975U using Tapatalk
              there should be another Q on the poll.
              Do you have more than ONE copier at home!
                • 14512
                #112
                If you have more than one copier at home you may have a problem. Lol
