Kyocera Backdoor Passwords
  • kyoceradude
    The Great Gazoo
    • Aug 2006
    • 442
    The M?&*%$ F&$#@!* just got rid of our backdoor passwords. This used to help out if you needed to reset counters or reprogram serial numbers if you swapped boards with another machine. If you update the firmware on the Voyager(C3232)or Harrier(6030,8030) and I think the Falcon 3's(can't remember if the 3036-3036 password worked on the earlier firmware) the 3036-3036 and 2341-2341 passwords are no longer available. The only one available is 1087-1087. Son's of B's. Anyone else catch this yet? Anyone know of other backdoor passwords for the Kyocera's?
    MAD! MAD! MAD! MAD!
    My mission here on Earth is to help all you Dum-Dums!
  • JSC
    Gimp
    • Dec 2006
    • 618
    You have to roll back the firmware, for 3036 3036 to work. its the only work-around i have found.........
    The gene pool could use a little chlorine.
    • Kirk
      • Apr 2011
      • 16
      Re: Kyocera Backdoor Passwords
      how do you back date the firmware, and do you know which firmware will work for the 3036 3036?
      thanks,
      Kirk
