solvent cleaners
    • 2621
    solvent cleaners
    What cleaner do you use to remove baked on toner and other dirt? We have used Mr McKenic Contact Cleaner & Lubricant but are now having problems locating a supplier. This stuff would remove almost anything but eventually ruins plastic parts with too many coats, it turns a clear toner bottle cloudy with one coat
    So what do you use?
  • JR2ALTA
    • Feb 2010
    • 2028
    Re: solvent cleaners
    I just carry alcohol, water/soap and a harsh "belt cleaner", I dont know of, or care about any magic bullet cleaner. If the company supplies can't do the job, the part needs to be replaced.
    • Shadow
      PHD in Sh!t Disturbing
      • Sep 2011
      • 455
      Simple Green
      this is what I have been using for the last 20 years. works great on just about anything. I still use alcohol for charge wires and windex for the glass.
      the simple green product works great on feed and registration rollers.
      $hit Happens - Deal with it and move on.....................................sigpic....................................Lock & Load
      • Hansoon
        • Sep 2007
        • 3349
        For toner build-ups on non-plastic parts: Acetone
        Hans
        “ Sent from my Intel 80286 using MS-DOS 2.0
        https://www.copytechnet.com/images/smilies/biggrin.png
        • mx270hb
          Overworked, Underpaid
          • Feb 2012
          • 26
          Acetone for toner
          Simple green for rollers
          Mr cleans magic eraser for covers
          • mikadonovan
            • May 2008
            • 2931
            I'm going to try that as the formula "K" stuff I use now is a little hard on the lungs.
            NEVER ASSUME ANYTHING
            • Zackuth
              • Aug 2009
              • 448
              We use Martin Yale Rubber Cleaner, which I think is similar to the stuff you are looking for. We also use soap and water, alcohol, and simple green.
              If at first you don't succeed, redefine success
              • charm5496
                • 2387
                Kwik Solv and Mean Green to clean the panels.
                Rubber Rejuv to clean built up toner and residue from those baked on situations.
                If it is really bad we use a chemical called Meter XIII which is an older press cleaner
                • mx270hb
                  • Feb 2012
                  • 26
                  The trick is to make the section of the sponge your using slightly damp. give it a few seconds to soak in and then rub away.
                  I am yet to find a mark I can not get off the covers.
                  Pens and tape residue are simple
                  boot marks require a bit more elbow grease.
                  I cut a sponge up into 3 strips.
                  Hope it works for you!
                  • blaze2000
                    • Sep 2010
                    • 232
                    General clean with 409
                    windex with a touch of rainx for glass and op panels
                    alcohol for corona/ grids
                    small bottle of d-ink for the real nasty stuff
                    • NeoMatrix
                      Senior Tech.
                      • 3514
                      I cut up a green scour pad (ones you scrub pots with), into 4 smaller squares, and use alcohol (metho) to clean the built up toner off most problem areas.
                      • DWise
                        • 895
                        Funds are pretty slim here... so we have had to resort back to the old "cleaning solution": SPIT and elbow grease.
                        Do for one what you wished you could do for everyone. - Andy Stanley
                        • copiman
                          • Sep 2011
                          • 861
                          A friend of mine that owns a pressure washing company told me about this. The name is LA's Totally Awesome. He gave me a container (64oz). the cost was $3.00 at Dollar General. It has a dilution scale listed on it. It list office machines with a 10 part water and 1 part Awesome. I make it a little stronger. I have been using it for 3 months now and I highly recommend it. You can get a smaller container for $1.00 to try. www.lastotallyawesome.com/Cached - Similar
                          There site has store locators.
                          • Jules Winfield
                            • Jul 2009
                            • 821
                            This stuff is actually really good. My wife discovered this stuff at the dollar store and it works beautifully on all kinds of stuff around the house. I never thought to try it at work, though. Brillianize, Ci7600 fuser oil, and CaiKleen RBR has been working great for the work stuff, so I never though to try La's...
                            But I'm trying, Ringo. I'm trying real hard... to be the Shepherd.
                            • banginbishop
                              grumpy old git
                              • Oct 2007
                              • 894
                              without trying to hijack the thread but what do you use for sharp main charges - the old manuals said polystyrene blocks to clean saw tooth charges
                              the new kit thats out there - ive tried all sorts and i end up getting new main charges as its a pita to try and clean.
                              oh and ive stopped useing solvent cleaners unless im desperate. more prefere glass cleaner, mr mckenic or wd40 based oil products.
                              Incontinentia Buttocks
