Language help: How are these called?
  • mrwho
    Major Asshole!
    • 4299
    Can someone please tell me how these are called and point me to some related easier-to-use alternatives (duct tape doesn't count).
    Mascan42
    Ibid
  • Debs1964
    • Oct 2010
    • 1693
    Re: Language help: How are these called?
    They are called terminal strips
    How about using crimps with a crimping tool
    There are 10 types of people in this world, those who understand binary maths and those who don't
    • Lagonda
      • Aug 2008
      • 1649
      Sorry Debs, but you ain't using those in my workshop! They were invented by Lucas the Prince of Darkness and are guaranteed to corrode and cause voltage fluctuations. Solder joint and heat shrink only please.
      • KenB
        Geek Extraordinaire
        • Dec 2007
        • 3944
        I vaguely recall the term "barrier strips", back from my high school electronics days.
        Of course, electricity was still somewhat of a novelty back then...
        • TheOwl
          • Nov 2008
          • 1732
          Terminal Strip
          Terminal Block
          Terminal Connector
          Unless you have a specific need for connecting and disconnecting at ease, then I am with Lagonda all the way with soldering the joints and using heat shrink.
          • Hansoon
            • Sep 2007
            • 3389
            Screw terminal - Wikipedia, the free encyclopedia
            Those thingys from Debs are sometimes used in automotive electrics around the seventies.........
            Hans
              • 37531
              Insulation displacement such as these are good for quickly connecting 2 or 3 leads together. Come in different sizes based on wire gauge.
              • Lagonda
                • Aug 2008
                • 1649
                Much better idea as they are filled with silicon gel which keeps the moisture out.
                • Lagonda
                  • Aug 2008
                  • 1649
                  Hans
                  Years fighting dodgy Lucas electrics in classic British cars from the 60's and 70's is the reason I hate the things.
                  • Imsdal
                    • Aug 2009
                    • 111
                    In sweden we call it sugar cubes.
                    Cheers
                    • mrwho
                      Major Asshole!
                      • 4299
                      Thank you all for the tips and clarifications. And yes, some of you guessed it - I need it for my old 20-yo car, I'm adding some aftermarket stuff.
                      Mascan42
                      Ibid
                      • Debs1964
                        • Oct 2010
                        • 1693
                        I didn't say I use them (I use duct tape ) Mrwho just wanted an alternative
                        • allan
                          RTFM!!
                          • 5462
                          the first time i encountered them, someone call it a chocolate block.
                          Whatever
                          • theengel
                            • Nov 2011
                            • 1784
                            Some people strip with wire strippers, solder, and cover with electrical tape.
                            I strip with my teeth (kids lost the wire cutters when they were using them on playdough), wrap together (they used the soldering gun for a wood burner), and cover with scotch tape (I just flat-out gave up on keeping electrical tape.)
                            • bigwul
                              • Jun 2014
                              • 60
                              A great deal of people may well disagree with me here but....a properly executed crimp joint will be mechanically and electrically more reliable than a soldered joint. The key to an acceptable crimp joint is that it must be "gas tight" -- the metal of the wire and the crimp lug are pressed so intimately together that if it were the lid of food can, it would be an hermetic seal. To get the best joint, the crimp lug should be matched closely to the wire gauge: The stripped wire should just slip into the lug with minimal side-to-side play. The crimping tool is important as well, as the most inexpensive tools found in automotive supply stores tend to crush the crimp lug and not properly compress it around the wire. Unfortunately, industrial crimping tools can be quite expensive, costing hundreds of dollars apiece, and one may need several different tools for different sizes and styles of lugs and terminals.
                              Avoid cheap knock-off crimp lugs from China and other moderately disreputable places, especially if they are to be used in automotive or aviation applications. The brand-name lugs and terminals from western European and North American suppliers will cost more, but are worth it in the long run by avoiding joint failures later. Also the wire must not be twisted - this can result in a 60% weaker joint.
                              In fact - a badly soldered joint is often worse than a crimp - even a good joint that has not been 100% cleaned of flux residue is a joint waiting to fail.
                              P.S I would call the other connectors Chocolate Blocks.......
