Headaches on KonicaMinolta 364e
  • Fuzzylogic
    • Aug 2016
    • 33
    Hello Everyone. I wanted to check if I am the only one having problems with copiers............Don't think so. I hope that someone may be able to shed some light on Konica Minolta and their little quirks.
    This 364e is a used machine that my client bought. When connected to the network it says that "the ip address is already in use, contact administartor" however when the patch cable is disconnected from the network and the ip is pinged there is no response. This is a good sign that the ip address is not used anywhere else however when the cable is connected after a few minutes the machine says again that
    "the ip address is already in use, contact administartor".
    I would like to ram clear this machine and install the latest firmware. Does any one have any firmware for this
    Regards
    Fuzzylogic
  • Aneurysm
    Administrator
    • Jan 2005
    • 1081
    Welcome Aboard!
      • 37300
      Re: Headaches on KonicaMinolta 364e
      If you expect to get help, post your problem to the correct technical forum.
      http://www.copytechnet.com/forums/konica-minolta/
      • bob marley
        • Jan 2012
        • 1339
        Welcome
        Live for yourself and you will live in vain. Live for others, and you will live again
