CANON error code E0112-0001
  • colly
    • Jan 2016
    • 10
    Hi i have a problem with a canon ir5030i after start-up it throws in error code E0112-0001 i have tried to re-seat the dustproof shutter drive with no progress. does anyone have a solution to this problem? pliz help
    thanks a lot
  • Aneurysm
    Administrator
    • Jan 2005
    • 1079
    Welcome to Copytechnet.com, the best Copier, Printer, MFP tech site on the internet!
    • colly
      • Jan 2016
      • 10
      Re: CANON error code E0112-0001
      Thanks a lot
      • colly
        • Jan 2016
        • 10
        Does anyone has a solution to this type of error code? Pliz help
          • 37393
          If you expect to get an answer to you r technical problem, post your question to the proper technical forum.
          http://www.copytechnet.com/forums/canon/
          • bob marley
            • Jan 2012
            • 1339
            thanks a lot
            slimslob is right. if u post to the correct forum your question can be seen by more Canon techs.
            Live for yourself and you will live in vain. Live for others, and you will live again
