ex-xerox tech
  • macbox
    • Aug 2016
    • 1
    ex-xerox tech
  • Aneurysm
    Administrator
    • Jan 2005
    • 1081
    Welcome to Copytechnet.com, the best Copier, Printer, MFP tech site on the internet!
    • bob marley
      • Jan 2012
      • 1339
      Re: ex-xerox tech
      Welcome
      Live for yourself and you will live in vain. Live for others, and you will live again
        • 37502
        Re: ex-xerox tech
        Glad to have you rejoin us.
        • igi
          • 1507
          Re: ex-xerox tech
          you are most welcome
          • Wally181
            • May 2021
            • 8
            Re: ex-xerox tech
            Hi,
            Just wondering if you can help me?
            I have a xerox 700i with integrated fiery machine was working fine then had a paper jam and needed to be restarted, now Command workstation can not find the server.
            Have checked all cables and connections and everything seems fine. Cannot ping the ip from my pc. The machine will also not print the start up page. All ip addresses are correct,.
            On error history print out 027-741 Job template server server connect fail.
            Can you advise a solution?
              • 37502
              Re: ex-xerox tech
              Originally posted by Wally181
              Hi,
              You are not off to a very good start.
              1. The Newbie Check In! forum is for just that, newbies to check in, that is introduce themselves. It is not for posting problems. There are technocal post for that.
              2. This thread is from over 4.5 years ago. That means it is dead and was buried. But you dug it up. That makes you a grave digger.
