How can I reset the SSL certificates for a BizHub C203 from the console
  • sa43
    • Aug 2016
    • 6
    We had to generate a ssl certificate in the printer on the webboard for papercut communication, something went wrong and the certificate, ie it looked like it did not finish creating, when the certificate was created it should display "if you want to add a certificate" By doing this on + 224e there was a problem, the certificate was created at the end when trying to connect by mozilla browser came up message whether you want to add a certificate - ok and went and works.
    I ran an old IE6 browser on an Xp window and did not. I ran Windows 98 with IE6 browser and there the certificate was added, the page tried to open for login but did not go by clicking F5 once there was an error message login to the web panel. I also did formatting the drive from the service level: logical and psychical
    In which place or at all it is possible to manually remove the ssl certificate in konica +203
    In this case I encountered for the first time, I was looking in the machine menu under the administrator to set the network / http server settings and ssl webDAV. I have two machines side by side the other is +353 compared in both menus and I have not found differences yet
    In the IP browser for web connection I now have the address https://192.168.0.180/, and I want to have: http://192.168.0.180/. The logon page does not show up to +203 at the moment, so it is not possible to make an https connection
    Re: How can I reset the SSL certificates for a BizHub C203 from the console
    would suggest you post that in the brand specific forum.. not everyone here checks the newbie forum
    • sa43
      • Aug 2016
      • 6
      In the forum for technicians, the site does not let me in and I can not move here yet
        • 37521
        Post your problem in the appropriate technical forum if you expect to get help. If you are having trouble, first respond to the email sent you when you joined so the system knows that you are not a bot then login with your name and password.
