Error E000000 on Canon IR2520
+ More Options
Posts
  • msquared840@gmail.com
    • Jun 2015
    • 29
    Dear Friends,
    i am experiencing Error E000000 on Canon IR2520 copier,
    before this error my client had called me to solve jamming problems, during the checkups i found the fuser/ fixing sleeve damaged which i replaced and the copier worked fine. i even made some copies for the customer to let him witness that the copier works fine.
    but when the customer tried to connect to the USB printer port to try and print-out some files from the laptop, the copier displayed the above error code.
    WHAT I HAVE TRIED TO DO SO FAR
    1. Tried to CLEAR the ENGINE, but still same problem
    2. Tried to reset the whole copier to factory default, but still same problem
    3. Tried to reinspect the fixing unit to see if every thing is in a good working position,
    every thing looks to be fine but the error doesn't go, PLEASE HELP.
  • Aneurysm
    Administrator
    • Jan 2005
    • 1094
    Hi msquared840@gmail.com, welcome to Copytechnet.com!
      Re: Error E000000 on Canon IR2520
      Originally posted by msquared840@gmail.com
      Dear Friends,
      this is newbie check-in.. please post in the canon forum
      • bob marley
        • Jan 2012
        • 1339
        ( http://www.copytechnet.com/forums/canon/ )
        Live for yourself and you will live in vain. Live for others, and you will live again
