How to install Konica Minolta C252 Transfer Unit
  • KMB
    • Jun 2025
    Hi, I am new to the forum and need some advice as how to change a transfer unit on Bizhub c252. We have bought the new kit but there was no installation instruction with it. A roller has separately come with the package which I believe needs changing too.
  • KMB
    Bizhub C252
    Very easy to do. just lift the two ends of the TU an pull towards yourself and it will move out. Don't forget to chage the roller afterwards which is also click on jub.
    • JJM
      Bizhub C252 Transfer Unit Replacement
      I have the new transfer unit, roller, etc., but although I understand if you're careful, replacing the transfer unit is easy. Problem is: I don't know where to begin! Where does one find the transfer unit - i.e., which door, where in the machine, etc.? HELP! And, thanks in advance!
      • JJM
        Wow! That was easy! Two screws, very careful removal of the old and handling and replacement of the new, and it's done. Two little black tabs to pull up on the opposing roller which then pops out, the new one in and tabs pushed down, and all's well with the World again.
