toshiba estudio350
  • mac12681
    • Feb 2011
    • 15
    toshiba estudio350
    Hows it going was wondering if you could help me out with a little problem I'm having. I have a toshiba estudio350 and I am getting f100 and then a f105 error message. I have restarted the machine with the 08 start and entered the 690 code and have rebooted the machine and it seems to work for awhile then goes back to the same thing. Is there anything i can do?
  • mac12681
    • Feb 2011
    • 15
    Can someone help me with the above problem
    • JustManuals
      • Jan 2006
      • 9838
      Just Manuals | The Internet's largest collection of manuals | Instant Downloads
      Paul@justmanuals.com
      • Mr Spock
        Vulcan Inventor of Death
        • Aug 2006
        • 2064
        Replace hard drive and reload firmware.
        • nazmi_exa
          • Nov 2009
          • 24
          try to format your HDD by pressing 3 and clear..then on machine.. key in 3 and press start.. then format it..08-690-2..then ..also 08-690-2
          • mac12681
            • Feb 2011
            • 15
            nazmi_exa on your reply were do i start the 3 and clear part
            • Mr Spock
              • Aug 2006
              • 2064
              If you do clear + 3 then you will have to reload the firmware as this wipes the drive.
              • dosolan
                thanks
                • mac12681
                  • Feb 2011
                  • 15
                  thanks mr spock for your help ithink im just going to buy a new hard drive woill i still have to do all that as well when i do
                  • mac12681
                    • Feb 2011
                    • 15
                    by the way do you know a good place to get one or which would be a better one to replace this one
                    • Mr Spock
                      • Aug 2006
                      • 2064
                      Any 60-80 gig pc hard drive will work. Try best buy or your local computer shop.
                      • nazmi_exa
                        • Nov 2009
                        • 24
                        40GB HDD IDE type is enough for toshiba copier..and its will work very well..but right now its hard to find brand new since SATA HDD replace IDE type...so for me i just buy second hand IDE HDD and try to scan it bad sector 1st by using my pc..not recommended to use large capacity HDD because its will effect loading time..bigger capacity will decrease its loading speed..
                        • mac12681
                          • Feb 2011
                          • 15
                          I found this one will this work for it
                          Capacity : 60 GB
                          Spindle Speed : 5400 Rpm
                          Data Transfer Rate : 300 MBps
                          Seek Time : 12 ms
                          Cache Size : 8 MB
                          Interface Type : Serial ATA
                          Form Factor : Product Descriptions : Toshiba MK6037GSX - 60GB - 5400Rpm - 8MB - SATA - 2.5" - 9.5mm
                          • mac12681
                            • Feb 2011
                            • 15
                            Seagate Barracuda 7200.7 - Hard drive - 40 GB - internal - 3.5" - ATA-100 - 7200 rpm - buffer: 2 MB
                            also found this one brand new
                            • Mr Spock
                              • Aug 2006
                              • 2064
                              Sata (serial ata drives) will not work as this model does not support sata. the second will work. I use 60-80gig just because they are reasonably priced and easy to find.
