I have Konica Minolta Bizhub C252, and it is connected with the simple wireless network, without any server. with work group environment, I tried to configure scan to SMB/FTP with host names. but no luck. any suggestion any idea....expert opinions will be appreciated.
Unable to scan with hostnames
Tags: bizhub, bizhub c252, ftp, hostname, hostnames, konica, konica minolta, konicaminolta, minolta, ops, scan, scan to smb/ ftp, tcp/ip, work
Hamood
I configured with the host ip address, it is working fine, so i believe no issues with firewall and trusted device. As there is no DNS server, all laptops are connected with wireless router. and i cannot make the static ip address for the laptops.
For example:
Host IP Configuration:
IP Address :192.168.1.23
Subnet mask :255.255.255.0
Default Gateway:192.168.1.1
DNS Server :192.168.1.1
and here is machine TCP/IP configuration.
IP Address :192.168.1.220
Any help will be appriciated
ThanksComment
Hamood
I would use the router as the host dns server. That "should" work. I've done it in the past. But I've hit some KM's that just won't work with a host name no matter what I try. Sometimes flashing the copier fixes, sometimes not. Worst case... if they have a "server" or copier that is always on and always there, just set that one to static (get permission first) and use that one to "host" the files. Then just made the folders on the laptops.Color is not 4 times harder... it's 65,000 times harder.They call it "TECH MODE" for a reason. I have manual's and firmware for ya, course... you are going to have to earn it.
