IR 2270 paper level control
  • garbanius9
    • Aug 2011
    • 26
    hi i just want to ask how to control paper level because if cassette is full printer shows that its emty
  • prntrfxr
    • 1627
    Re: IR 2270 paper level control
    Post your question in the Canon forum if you want a faster reply. This is the newbie welcome forum. Welcome, BTW.
    Life should NOT be a journey to the grave with the intention of arriving safely in an attractive and well-preserved body, but rather to skid in sideways - Coke in one hand - chocolate in the other - body thoroughly used up, totally worn out and screaming "WOO-HOO, what a ride!".
    • charm5496
      • 2387
      There are a combination of sensors, arms and levers that measure the amount of paper in each tray. Check to make sure your tray is not cracked or broken, and do you hear a ratcheting sound when you push the tray into the machine? If you do not then a new pick up assembly might be needed as well.
      • ernesto
        • Oct 2011
        • 430
        HI
        <Symptom>
        When the machine is left unattended for a period of time, Pick-Up Delay Jams or lifter failure (i.e., failing to move
        up) can occur when the machine is turned on the first time (e.g., in the morning).
        <Cause>
        The friction in the area of contact between the Lock Cam and the Leaf Spring increases, preventing the 46T Gear
        from rotating even when the Pick-Up Solenoid goes on (or, the Gear starts to rotate after a delay) and ultimately
        causing Pick-Up Roller or Lifter operation failure.
        <Factory measures>
        Add a roll to the Cam surface to decrease the friction between the Lock Cam and the Leaf Spring and in addition,
        increase the force of the Spring to raise the latitude.
        FB6-3392-020 spring leaf
        FB6-7078-000 cam lock
        FF6-2397-000 gear 46T
