Noob need Advice for Used Multifunction Laser machine for Home use!?
  • treysoucie
    • Aug 2025
    Ive been scouring craigslist for a good color copier/scanner/printer for home use. My home use is fairly heavy however, and an Inkjet just wont cut it. I am in the oil and gas industry and as a designer/engineer i am constantly working from home. I need to be able to do all of the copy/print/scan functions on everything from 4.25x6.5 pamphlet paper all the way up to 11x17 in B&W and color. with a budget of 1000-1500 bucks im wondering if it will even be worth messing with? are the 5-10 year old machines going to be reliable? What are some good reliable and fairly efficient machine models that would fit the bill? Ive put some links to models im looking at in my area, let me know what you guys think...
    Xerox DocuColor 3565 Xerox DocuColor 3565 Copier/Printer
    Sharp AR-BC320 Sharp printer AR-BC320
    Sharp Ar-m257 Printer,copier Scanner Sharp Ar-m257
    Kyocera KM-3035 --- Kyocera KM-3035 Digital Copier / Commercial Copy Machine / Clean
    Kyocera KM-3530 KYOCERA COPIER PRINTER FAX MULTIFUNCTION
    HP Color Laser Jet CM2320fxi MFP HP Color Laser Jet CM2320fxi MFP
    Toshiba "eStudio" C Series CLOSED OFFICE MUST SELL $23,000 '09 MODEL TOSHIBA COPIER/PRINTER/SCAN
    Xerox Phaser 8560MFP Xerox Phaser 8560MFP
    TOSHIBA E STUDIO 451 TOSHIBA COLOR COPIER PRINTER LASERJET MULTIFUNCTION
    Ricoh Aficio SP C221SF Ricoh Aficio SP C221SF Multifunction Desktop Color Laser Printer
  • zoraldinho
    teacher-guide-expert-guru
    • Mar 2008
    • 5018
    Re: Noob need Advice for Used Multifunction Laser machine for Home use!?
    My vote for HP.
    • Mr Spock
      Vulcan Inventor of Death
      • Aug 2006
      • 2064
      Xerox 3536 potentially expensive parts and labor if repairs are needed.
      Hp I do not think that supports 11x17.
      Toshiba 3510... I would take this if all the service logs are there. It had some mods and works well up to 20k per month.
      toshiba 451 (page expired) but would not recommend unless you can repair and clean weekly.
      Sharp and kyocera I do not know.
      the last 3-4 post are expired.
