Newbie needs advice
Re: Newbie needs advice
First off, welcome to the site Mark.
Secondly, you will probably get more replies and advice if you post this question in the proper forum... I would suggest posting it in "Rants, Raves, and Everything Else".
Hope this helps.Do for one what you wished you could do for everyone. - Andy StanleyComment
Welcome to the forums. I'd recommend the bizhub. I used to work on Ricoh color and any bizhub color is better than the c6000. Can't say I've heard anything bad about the Xerox docuhub. With any business class color mfp be sure to factor in the cost of Image Units. Some will have an Image Unit which is contains both drum and developer. Others will have the drum and developer sold as separate units. Prices can vary depending on the brand, model, or Image Unit vs Separate drum/developer. Ricoh's might be cheaper but Bizhub's will have fewer problems IMHO.The chance that higher life forms might have emerged in this way is comparable to the chance that a tornado sweeping through a junkyard might assemble a Boeing 747 from the materials therein. -Fred HoyleComment
