Checking in, with Canon IR1025 USB problem
  • bnilsson
    Greetings from New York's Capital Region! I run a one-person business and have been long reliant on copy machines. My Canon ir1025, purchased a few years ago, has been a great workhouse, but some time ago I had what I suspect was a lightning strike, as I lost the USB connectivity on it and a Brother printer. I replaced the Brother,
    but I'd like to get the printing capability back on the Canon, which has no other networking capability.
    Is the USB port on a board I could easily (or not even easily) replace? Can you steer me to a good source for parts? Thanks!
    -- Byron Nilsson
  • Aneurysm
    Administrator
    • Jan 2005
    • 1064
    Thanks for joining our site, we look forward to seeing more posts from you in the future.
    • SCREWTAPE
      East Coast Imaging
      • 3396
      Re: Checking in, with Canon IR1025 USB problem
      -- Byron Nilsson
      I will be more than glad to help you out.
      There is a case when connecting the imageRUNNER 1023/1025 to a pc via an usb cable it would not recognize it as a printer. Does the PC recognize the hardware (iR1025)
      Replacing the IP PCB (FM2-6094-000) and the ROM PCB (FM2-6082-0000) resolved this issue in this case. Part numbers vary depending on the serial number of the machine.
      If you need,or want to try to repair your canon 1025. I can give you a quote on these pcb's and get them to you. Contact me below.
      Replacing these pcbs is really easy. If your somewhat tech savvy, you can probably do it.
