Lexmark 748 dte, mfp reads on op panel "load paper in tray 1"
  • benalvarez
    • Feb 2015
    • 27
    The customer was annoyed that the mfp was indicating that the paper was low and it would only work if the tray was full of paper. I removed the tray and removed the ream of paper to see if the paper size was set correctly, it was. I then removed the rear panel then ran an internal device statistics page, while I shined my flashlight in the back to see if the pick tires were turning on the paper, but because of the nature of the tires I couldn't decipher if the tires were moving (fine treads on pick tires). I called Lexmark tech support and they steered me down the rabbit hole saying that I needed a new pick arm assembly. After I ordered the new pick arm assembly, I returned to the customer, a little apprehensive about installing a new pick arm assembly in this virtually new mfp with 97K clicks on it and it was one year old. I removed the tray with the paper set at the correct paper size for plain paper (8 1/2 X 11) and stood it up on one hand, keeping the quarter ream of paper in place with the other and being the casual minded observer that I am, I noticed that there was a gap behind the paper of a few millimeters. Definitely enough slop to cause the paper to not feed out of the tray. I set the paper tray smaller to accommodate the paper just a few teeth on the tray and magically the mfp began churning out paper. Can anyone explain why this happens?
    • 37319
    Re: Lexmark 748 dte, mfp reads on op panel "load paper in tray 1"
    This is the wrong forum.
    • Iowatech
      Not a service manager
      • 3930
      Can't do that right now, but you might find an answer here:
      http://www.copytechnet.com/forums/lexmark/
      Good luck, and welcome to CTN!
      • bob marley
        • Jan 2012
        • 1339
        Welcome
        Live for yourself and you will live in vain. Live for others, and you will live again
