I've found myself on this forum a few times relating to issues I've had with my Konica Minolta Bizhub C252. So far I've been able to resolve every issue. So thank you all for your contributions on this site! Now I'm searching for a fix to a malfunction error C5102. It looks like I may need to replace the motor.
Konica Minolta Bizhub C252 user/technical
Tags: None
Re: Konica Minolta Bizhub C252 user/technical
welcomeLive for yourself and you will live in vain. Live for others, and you will live againComment
Welcome to Copytechnet!
You might want to post your request here:
I'm pretty sure that's where most of the people with Konica Minolta experience are at.Comment
daya1969
Thank you for the welcomes .
And yes, I had to replace the motor. After replacing the Main Motor (M1) I had to reboot to clear the malfunction error by turning off the main power then holding down the Utility counter while turning it back on again.Comment
