Canon IR-C2550
  • roman canada
    • Jun 2025
    Canon IR-C2550
    Hi I'm new to this so please bear with me.
    My wife and I run a small business and use an IR-C2550 as a printer, scanner and fax. It is a important tool for us. I have been doing all the maintenance on it. Presently at 65,000 count there are horizontal lines appearing on the pages. My impulse is to replace the drums. yes/no All of them? is there something else that needs to be replaced?
    tks Roman
  • Aneurysm
    Administrator
    • Jan 2005
    • 1064
    roman canada, thanks for posting, we hope to see you back soon!
    • bob marley
      • Jan 2012
      • 1339
      Re: Canon IR-C2550
      Welcome
      go to http://www.copytechnet.com/forums/canon/ where am sure u will find solution to ur problem
      good luck
      Live for yourself and you will live in vain. Live for others, and you will live again
      • ernesto
        • Oct 2011
        • 430
        Re: Canon IR-C2550
        Hi can we see a picture about the problem..?
        • roman canada
          Re: Canon IR-C2550
          Here is a pic of the issue:
          • zoraldinho
            teacher-guide-expert-guru
            • Mar 2008
            • 5005
            Re: Canon IR-C2550
            Still waiting for the pic!
            • roman canada
              Re: Canon IR-C2550
              I am concerned about the streaks. They even show up on regular black and white as a black streak on the side of the page for example.
              • tech28
                • Jun 2013
                • 434
                Re: Canon IR-C2550
                Have you cleaned the laser glass(all four colors) with the wand that's inside the front door? If you have, replace the colors that have the lines on them. You do not have to replace all of them at once. Some drums will wear faster than other ones.
                • tech28
                  • Jun 2013
                  • 434
                  Re: Canon IR-C2550
                  Looking at the test page, you have another issue, some of the lines are going all the way thru, all the colors, Possible transfer belt, not cleaning or worn. You should be able to see that on the belt. Have you opened it up to see that area of machine?
