Capture Quotes
  • copiman
    • Sep 2011
    • 861
    Capture Quotes
    I have seen where someone responds to a post and either captures pieces of a post or captures some from several posts and includes them in their response. Exactly how is this done? This will help me when responding to more than one post.
  • ZOOTECH
    Senior member of CRS
    • 3375
    Re: Capture Quotes
    Next to the "Reply to Quote", there is an icon for "Reply to Multiple Quote".
    • copiman
      • Sep 2011
      • 861
      Re: Capture Quotes
      Thanks ZOOTECH. I did as you said to respond with this post. Once I select "Reply to Multiple Quote" what is the procedure to capture quotes from multiple posts? Here is an example of what I'm asking about. look at post #19.
      http://www.copytechnet.com/forums/ra...es-them-2.html
      • ZOOTECH
        • 3375
        Re: Capture Quotes
        I'm not positive, but I think once you select 'multi quote', you can then select the 'reply to post' of the different threads. (The FAQs weren't much help)
        • copiman
          • Sep 2011
          • 861
          Re: Capture Quotes
          You are right. I did as you thought and it did it. Thanks for your help.
