more bugs ??
  • Michael
    • 158
    more bugs ??
    if i select NEW POSTS i get a blank page ....
    https://www.copytechnet.com/forums/s...e=vBForum_Post
    if i select the green Numers and then VIEW ALL POSTS i get a blank page
    https://www.copytechnet.com/forums/search.php?do=getnew
    i use firefox 84.0
    anybody same ?
    My profile is not working at the moment. The profile you see is not mine. Board redirects to a wrong userprofile. So you CAN´T REACH ME over the profile via SEND PRIVATE MESSAGE and even not over regular Email too
    You only can contact me if you click my name on a post and select PRIVATE MESSAGE straight from there.
  • ZOOTECH
    Senior member of CRS
    • 3375
    Re: more bugs ??
    i use firefox 84.0
    anybody same ?
    • Blizzoo
      • Aug 2013
      • 608
      Re: more bugs ??
      I go the same problem as Zootech and I'm used now in using Today Posts.
        • 37533
        Re: more bugs ??
        I just tried it and the same for me. FF 84.0 also. But then again it is something that I don't use. When you are on the Forum page the all Copier Technical Discussion and Fax & Printer Technical Discussions forums that have posts in them that you have not yet read are indicated as such by a darker bubble in front. Same is true of individual threads in the forums. The only problem comes in when someone posts something Print Only format (last 5 letters of the name spell the word print). The only way to clear them is to Mark Forums Read under Forum Actions which marks everything as read.
        • Michael
          • 158
          Re: more bugs ??
          • tsbservice
            Field tech
            • 8020
            Re: more bugs ??
            i use firefox 84.0
            anybody same ?
            This is how it works. Few very minor bugs. We've gotta live with them.
            I learned to don't care as long we are alive and kicking here at CTN.
              • 37533
              Re: more bugs ??
              The last time it was updated caused major problems like crashing the entire member database. Luckily aneurysm had a recent backup and was able to restore. Most members only lost a couple of items from their history. Actual posts and subscriptions were not lost.
                • 37533
                Re: more bugs ??
                To my knowledge the last time we were hacked was before updating to this version. He moved forum from a http:// server to an https:// a little over a year ago.
                • Michael
                  • 158
                  Re: more bugs ??
