How to search forums for old posts
  • kuby
    • Oct 2007
    • 1395
    How do you search for old posts that you made or started. Tried and only one shows up? Very frustrating.
    • 37316
    Well first off have you tried looking at your "User Profile" "Activities" tab. By Default it only shows the last month but that can be changed by using the Filter button options. There is also an Advanced options for the filter. I am seeing a lot more than just 1 on your Activities tab.
    Oh and why did you post your question here instead of Sire Feedback & Questions
    • kuby
      • Oct 2007
      • 1395
      I have tried the advanced options. Just keep messing with it I guess. Thanks
        • 37316
        Which advanced option, under Search or Filter.
        • kuby
          • Oct 2007
          • 1395
          Thanks will try it later...
            • 37316
            It looks like Aneurysm moved this to Site Feedback & Questions
            • Aneurysm
              Administrator
              • Jan 2005
              • 1081
              To get to the advanced search, click the down arrow in the search box in the upper right area of your screen, then click on Advanced Search at the bottom of the search options
              In the Advanced search enter your username in the member field, and hit search, if you only want to see the topics you started you can check the checkbox to the right of the Member field.
              • Blizzoo
                • Aug 2013
                • 605
                Just noticed that you can find your own posts in one place: select your username top right -> select My Profile -> select About -> scroll to the bottom and click the Find all posts under the Links
                • tsbservice
                  Field tech
                  • 7970
                  Good to know but it's limited to only 500 posts.
                    • 37316
                    tsb, I realize that 500 is no where near enough for people like you, BC and I but more than enough for many of those here.
                    Also as I mentioned in the first reply to this thread look at your "User Profile" "Activities" tab. Set the time filter to All Time and use the Advanced under filter to select a date range. I tried setting the range to the first month I was a member and the posts were all there.
                    • tsbservice
                      Field tech
                      • 7970
                      Same but short is to choose "my recent posts" which is right under "my profile".
