Unignore
  • tsbservice
    Field tech
    • 8054
    Unignore
    Aneurysm, I need to unignore some members but when I click on user and press Unignore button it appears like that.
    • 37597
    I believe you need to be in your Ignore List in order to unignore someone. Go to your "User Settings - Account" and scroll down. The last item is your ignore list. Click on the "x" after a name to remove them. There is also an entry box at the bottom for adding names.
    • tsbservice
      Field tech
      • 8054
      Yes that's correct. It will work that way but I wanted to do it from new name cards quick menu.
      I have a feeling that because someone of my ignore list posts in KM forum and then often forum is marked as unread even I know I read all topics.
      BTW happy and prosper new year slimslob!
      You are inspiration for younger techs!
        • 37597
        Yeah I have encountered that problem with the new software. With the old software you could see the post listed in the thread and had the option of viewing the post.
