bizhub c284e. so we used an old hdd from another printer with the same model and we did the physical format. however, the physical format would not show the ok button and it would stop at 100% and do nothing. pls help me out thanks
Bizhub c284e physical format not working
Re: Bizhub c284e physical format not working
Can also clean the drive using CMD prompt like Konica want's you to do on USBs before firmware, just adapt the drive to your PC using a cheap adapter and open command prompt.
Type "Diskpart" then enter. "List Disk" then enter. "Select Disk #" then enter. "clean" then enter. "Convert GPT" then enter, "Convert MBR" then enter, "clean" then enter.
Bizhub will now think the drive is brand new and partition it. Works for the Storage Board issues too if boot diag shows its a software issue like being Read Only. -
Try a logical.
thanks and do i need to use sata only or do i need 2 cables to connect the hdd to my computer. if i need 2, then where would i go get the cable cuz i only have the sata and the other power cable doesnt have any matching ports on my motherboard.Comment
There are adapters that convert both Power and Data to USB. If you search "Sata to usb" on Amazon the entire first page handles both for between $10 and $30.
If you wanted to plug it into the internal right now, Data would go to your motherboard and power to Power Supply.Comment
Sorry, can't help on the HDD formatting problem, but I'd suggest you put this question over in the KM forum, where people who can help would be more likely to see it.Comment
In fact it was seen(and answered) at least from one of them, but you and JK are absolutely correct where this thread should belong. Imho that may be part of work missing moderators can do easily. Nevertheless Aneurysm do wonderful job for one man.A tree is known by its fruit, a man by his deeds. A good deed is never lost, he who sows courtesy, reaps friendship, and he who plants kindness gathers love.
Blessed are they who can laugh at themselves, for they shall never cease to be amused.Comment
