I have this printer epson stylus R2880 model , the problem is, it is always giving paper jam and has a shadow print image when tested. According to the blink indicator( power of, paper jam and ink low indicator flashes together.) foreign object inside printer or printhead. Can somebody tell me what should be the problem. Thanks
Epson Stylus R2880
Tags: None
Re: Epson Stylus R2880
ruben is right. Also your join date makes it appear you should know better.
But maybe last week for you was something like was for me, and you just let the spoon fly off that hand grenade.
That never ends well, avoid doing that.
Also, you will find it more productive if you post a query like this here:
http://www.copytechnet.com/forums/other-brands/
Keep in mind that you are most likely the only person here that can see and hear your machine. So unless the machine is having a common problem you will need to be somewhat more descriptive.Comment
