I have a problem with a KM C280 making a grinding noise on startup, so tried to search in that forum on "grinding", but the search goes over the whole site. I also tried adding "bizhub" to reduce the hits to the KM forum, but the search just seems to take the union of the two search terms rather than the intersection, even if I use "+" (as in "bizhub +grinding" or "+bizhub +grinding"). "Advanced" search seems to offer no way to do this. How can I refine the search?
How to confine search to a specific forum
Re: How to confine search to a specific forum
Forget about the search function in this panel.
One of our colleagues here once posted following link as an alternative to search in Copytechnet:
301 Moved Permanently
Works well.
Hans“ Sent from my Intel 80286 using MS-DOS 2.0“
https://www.copytechnet.com/images/smilies/biggrin.png -
Yeah, with all due respect to Douglas Adams' "Dirk Gently", I consider the standard search here as more of a "Zen Search": while it might not take you where you want to go, it will sometimes take you where you need to go. But not often enough if you are in a hurry.
I use the same search Hansoon does, and it is a lot better than the standard search here. Also, it is built on the Google search framework, so you can use standard Google search qualifiers if you want.Comment
Works well.
And that approach mostly works, because users of this site have the discipline to confine most bizhub questions to the Konica Minolta forum. I had just hoped/thought/expected(?) that this content-rich site would have a more productive internal search mechanism. Thanks for saving me (and, with luck, others) a lot of time trying to dope out the copytechnet.com search engine.
[BTW, I learned another quirk while composing this reply: I was interrupted for an hour in the middle of the reply, and when I came back found that "Auto-Save" (which happens twice a minute?) has a severe limitation: It gets flushed when you are automatically logged out for inactivity. Oh well...]
Yeah, with all due respect to Douglas Adams' "Dirk Gently", I consider the standard search here as more of a "Zen Search": while it might not take you where you want to go, it will sometimes take you where you need to go. But not often enough if you are in a hurry.! I feel illiterate not to have known the Dirk Gently reference, and thank you for improving my classics education. I love Wikipedia's description:
Originally posted by WikipediaDirk Gently operates his Holistic Detective Agency based on the "fundamental interconnectedness of all things", which relies on random chance methods to uncover connections between seemingly-unrelated cases. He claims that he follows the principles of quantum mechanics, and although the majority of his clients suspect he may be a conman he often produces surprising results.)
Originally posted by IowatechI use the same search Hansoon does, and it is a lot better than the standard search here. Also, it is built on the Google search framework, so you can use standard Google search qualifiers if you want.Comment
This script will do a Google search on this site.
Create a new text document with notepad and save the following code as search copytechnet or whatever you want but the file extension has to be .bat
When run a command prompt pops up and you type your search terms, press enter and Firefox or Internet Explorer opens with the Google results, it saves you having to type the following into Google each time "site:http://www.copytechnet.com/forums/canon/"
It searches the canon subforum but can be modified to any sub forum, just alter the red text and change it to what you see in the address bar of your web browser. For example if you wanted to search the Ricoh forum put ricoh-savin-gestetner instead of canon.
The blue text can be changed to whatever you want.
Enjoy
Code:@echo off set "google=http://www.google.com/search?q=" set "site=+site:http%%3A%%2F%%2Fwww.copytechnet.com%%2Fforums%%2F[COLOR=#ff0000]canon[/COLOR]%%2F" set /p "string=[COLOR=#0000ff]Search Copytechnet canon for[/COLOR] [COLOR=#0000ff]:[/COLOR] " set "string=%string: =+%" start "" %google%%string%%site%
Ah, of course: That's a good refinement on what others have said: google with the "site:copytechnet.com" parameter, but extended into the forum level. Regardless how you choose to automate/script it, that is the key to refining the search (though I have found that my questions for Konica Minolta almost always hit in that forum anyway). Thanks.Comment
