Coin Vend
  • mansart
    • 852
    Coin Vend
    Does anyone know of a vend unit (for library ) that will vend copy, print and scans????
    Scans being the mystery to me. Vend copy and print easy......vend a scan Not so sure.
    Any info greatly appreciated
  • allan
    RTFM!!
    • 5459
    Re: Coin Vend
    If you can get a trigger signal from the scanner and add some external logic to distinguish between "start of print" and scans it could be possible with an old school vendor.
    But i would not try that on a new machine.
    You would be more into logic electronics than printers.
    Not sure if the new API stuff could help.
    Whatever
    • Ctl-Alt-Del
      • Jul 2006
      • 430
      Re: Coin Vend
      I'm not sure about the scans, but you can contact ACDI (ACDI Powered by Papercut) and if it can be done, they can do it.
      • Tonerbomb
        AutoMajical Resolutionist
        • Feb 2005
        • 2589
        Re: Coin Vend
        Ditto, I've used their coin ops with good results and excellent support. Paper cut will handle the scan part very soon if not now.
        Mystic Crystal Revelations
        • NeoMatrix
          Senior Tech.
          • 3514
          Re: Coin Vend
          RE : Coin Vend scanner charge.
          Assuming platun/glass top scanning only: (No public coin vend would use an RDF surely...)
          A simple cabinet style magnet glued onto the scanner lamp ass'y any where you like, which then triggers a simple reed switch at the same locale.
          You now have a simple safe scanner counter signal to interface your electronics into.
          Double counter :
          Place two reed switches on the scanner frame for A4 and A3 page lengths.
          You must charge twice for A3 otherwise people will scan two A4's at the same time and you'll only charge them for one.
          Hint :
          Place the A3 scan reed switch at the end of A4 scan page length. People will also learn that scanning in A4R(SEF) mode will cost them twice.
          • cricketsi
            Field Tech
            • Feb 2020
            • 14
            Re: Coin Vend
            We've found coin units from SEM have any option we've needed so far. ITC will also do it.
            Here's SEM's website, just in case. Home page
            Did you end up finding a solution?
              Re: Coin Vend
              4 year dead thread.
