Facetime/ Messenger-Video with Customers
  • FrohnB
    • Jul 2017
    • 1919
    Just wondering how many here use Facetime or Messenger Video as a "diagnosis" tool when a customer calls in and says they have a broken part, or a strange noise.
    Until this week I had never used them for this purpose. Now suddenly, I've done it THREE times this week! 2 for broken parts (Paper guide fell out, and a Broken Transfer unit) and One for a strange noise.
    I wasn't the one to Initiate the idea of Facetime in these instances, the customers did, but found it to be VERY helpful. With the video letting me hear the noise in action, and a savvy end user that was able to navigate a couple of SP's with instruction , the noise issue was narrowed down to a development unit grinding on a C4503 (no codes or anything like that), and I was able to grab the unit in question and get the machine fixed in a timely manner once onsite. Without that facetime interaction, I may not have grabbed the part needed. Those machines have lots of different "strange noises" that customers complain about.
    Curious to hear if this is a common practice, or an emerging practice.
    Omertà
  • copiertec
    • Jan 2016
    • 2199
    Re: Facetime/ Messenger-Video with Customers
    I haven't used face time or messenger for this purpose, but have had the client send it to email for us to view, especially at remote locations.
      • 16374
      I have not. The idea hasn't even occurred to me but it's a GREAT idea. I will give try. Thanks.
      PS - I do use remote login for network issues and to change settings on copier.
      • spanky
        • Sep 2012
        • 468
        I used facetime once when a customer could not navigate through the touch panel to perform a job.
        I had trouble talking them through it, so we used facetime so I could see the touch panel and talk them through the job.
        • nhyrum
          • May 2016
          • 55
          Seems like a great way to help them navigate a menu. Noises are so odd and you don't really get the spatial hearing you need to help pinpoint where it's coming from, so I don't see it being much help there. I've had costumers text me pictures or videos of copy quality and jam issues before
          Sent from my SM-G975U using Tapatalk
          • progoffice
            • Nov 2008
            • 334
            We use Facetime to assist newer techs troubleshoot issues they are having in the field. We haven't used it much for the customers, but I can see how this would help in those situations too.
            In the Kyocera world, KFS allows you to both see the customers touch panel and on some models go a step further and actually push the buttons to help train the customer remotely. I'm not sure if other manufacturers offer this, but I think it's pretty cool.
            • tsbservice
              Field tech
              • 8002
              KonMin has something similar it is called Remote panel, pretty good tool mainly I can go even in Service mode remotely. As for video calls with clients I use Viber here it's much common app but same is WhatsApp.
              • lees
                • Apr 2011
                • 95
                We have used face time several times with customers to help with different problems. We can even facetime with other techs in the field to help them out. We also have customers send different things via email. I have used facetime many times to help my kids fix their cars, air conditioners, and even lawn mowers. There are many uses for facetime to help with repairs of different things.
                • paulg
                  • Jun 2007
                  • 278
                  If you use video chat then try to ensure you got the Remote assist app working on the device if at all possible.
                  Letting customers be aware of SP modes can be a very interesting path. Yes, of course any keen user could find them out anyway. But you suggesting using, possibly on a video that's recorded or witnessed by multiple customers could really backfire.
                  If you have no option but to supply SP modes or inside tricks that typically are not mentioned to customers because of the risk to the device, their office or indeed a human being. Then I would make sure you have a worked out couple of sentences stating these should never be used without guidance of a skilled technician blah blah. Possibly wise to follow up with an email or letter if need be.
                  Of course most customers will be sensible, but we all know the customer who you show a trick and then they use regardless of the actual symptoms or state of device.
                  We all possibly know the Customer or smart Tech who put the fusing reset codes or some other fix that should not be used unsupervised on a post it note by the Copier.
                  Remote work is very much supported by all until something goes wrong then neither your manager or the customer will be in your corner if things go badly wrong.
                  1. Try to think through possible fixes before you suggest. What's the worse that could happen if they use?
                  2. Always state like a robot they should never use this fix with out conferring with your company.
                  3. If suitable and no confidential information is being displayed then try and record. Of course find out the law locally for what you need to do with regards making those involved aware your recording and how to store the recordings.
                  4. Document and keep notes on a system YOU can access always. Pen and a notebook often the best way.
                  • Bix
                    • Apr 2018
                    • 1421
                    Konica Minolta made an instrument just for this. It is called AIRe Link. I believe it is an acquired company.
                    You send a link to the customer which he will open on his mobile. He and you don't have to download anything. In fact it is a web application. You will have the opportunity to see and indicate what she/he must do.
                    Link: AIRe Link Visual Remote Support | Konica Minolta
                    For now it is also possible to make a free account.
                    • srvctec
                      Former KM Senior Tech
                      • Oct 2009
                      • 827
                      [ATTACH=CONFIG]46979[/ATTACH]
                      That's kind of cool. Never heard of it and I'm a KM only tech.
                      Started in the copier service business in the fall of 1988 and worked at the same company for 33.5 years, becoming the senior tech in 2004 but left to pursue another career on 4/29/22.
                      • tsbservice
                        Field tech
                        • 8002
                        • srvctec
                          • Oct 2009
                          • 827
                          Aaahhh, well that's why then. I sure wish KM would get things the same on both sides of the pond so we're (I'm) not confused!
                          • tsbservice
                            Field tech
                            • 8002
                            Imho you're on better side. And I mean from my experience TABS(Toshiba America Business Solutions) where way ahead from TEC(Toshiba Europe Corporation). Same I see from KM.
                            Stay safe Brother.
                            • Bix
                              • Apr 2018
                              • 1421
                              Yes, it is very strange! They look like two different planets. For some things, we are in the future while for other prehistory.
