instant plastic
  • felix
    • Oct 2011
    • 24
    instant plastic
    anyone remember or know what happen to instant plastic? it was a 2 part app.. supper like glue and fine plastic. stuff was incredible. it was sold by a tech aid place in orange county California.
  • allan
    RTFM!!
    • 5462
    Re: instant plastic
    Do you mean Q-bond.
    I use this stuff a lot but this stuff goes rock solid. You can mend broken gears with this if you are patient enough.
    Before this i used super glue and bicarbonate of soda.
    Whatever
    • felix
      • Oct 2011
      • 24
      Re: instant plastic
      Originally posted by allan
      Do you mean Q-bond.
      [ATTACH=CONFIG]27914[/ATTACH]
      i mend gears as well with instant plastic. stuff was like granite.
      Thank you gonna order some give it a try.
      • cscce
        • Jun 2014
        • 156
        Re: instant plastic
        I've used a product called PlastiFix.
        • CT Copier Repair
          • Mar 2010
          • 304
          Re: instant plastic
          plastipair mcm electronics
          • Darren
            • Mar 2015
            • 5
            Re: instant plastic
            Hey All: I've used Oatey Fix-it Stick in applications where medium strength, fast cure time and a putty form are required and when a piece(s) of the part is missing. You can get it at any of the big box home improvement stores. I've used it succesfully for components that are no longer available. It literally hardens within minutes after kneeding it together so you must work quickly with it before it cures!
            Darren
            • Gar the pilot
              Re: instant plastic
              Is Q-Bond better that Super glue and bicarbonate of soda? We used Instaplastic in the past and the boss said to just use the superglue route now, but if Q-bomd is a lot better I may be able to talk him into trying that.
              Gar the Pilot
              • qbert69
                • Mar 2013
                • 1152
                Re: instant plastic / plastic repair
                I find JB Weld Products to be quite good!:
                Epoxy & Adhesives | J-B Weld
                I like the 5 minute epoxy!...I usually do a quick set with superglue (cyanoacrylate) and then use the 5 minute epoxy to give it strength!
                There is also Methylene Chloride Solvent Cement!:
                Object moved
                Water Clear and highly evaporative, it bonds acrylic to itself, basically melting or welding it--no heat involved!
                It cures quickly for a strong bond.
                PS--Thanks for the superglue and baking soda trick!!!
                REACH FOR THE STARS!!!
                Konica Minolta Planetariums!
                • allan
                  RTFM!!
                  • 5462
                  Re: instant plastic
                  Gar the Pilot
                  I also used to use the Bicarb and Super glue mix, not close as strong as Q-bond. I have fixed gears that is broken in two, door latches(metal to plastic) broken of paper tray faces, ADF latches and things to many to mention. does not take on some oily plastics the you just encase the thing you need to keep together in the stuff. Its a must for a toolbag.
                  Got me out of a lot of jams.
                  Whatever
                  • subaro
                    • Oct 2010
                    • 1274
                    Re: instant plastic
                    JB weld 5 min epoxy is the best i have found so far. JB Weld has a plastic epoxy also.
                    superglue and baking soda is good, but more as a filler rather than a super strong bond.
                    superglue on its own is very good when done the correct way and let to cure at least 30 min for maxmium effect. \
                    then there are different manufactures of super glue, which may not all have the exact formulars and therefore produce diffrent results.
                    There are new stuff on the hardware now i see that i have not tried. super glue with the separate activator is supposed to be very good from what i have read and seen on you tube demo. It comes in two piecies, the activator which you apply first and then the superglue.
                    • qbert69
                      • Mar 2013
                      • 1152
                      Re: instant plastic
                      So what does the "activator" do?...prep and strengthen the bond???
                      I do know that there is a catalyst out there called "Zip Kicker" that shortens the cure time of CA Glue drastically:
                      Super Glue Corporation | Zap//Zip Kicker line | Zip Kicker Aerosol Can
                      Also the debonder has it's uses!:
                      Super Glue Corporation | /Zap | Z-7 Debonder
                      • subaro
                        • Oct 2010
                        • 1274
                        Re: instant plastic
                        The avtivator prime hard to bond surfaces that is to be bonded so that the superglue will achieve a better bond. similar to painting a raw piece of metal, prime first and then paint.
                        google the following below and check out the manufactures like locktite
                        2-part all plastics super glue
                        • subaro
                          • Oct 2010
                          • 1274
                          Re: instant plastic
                          how to prevent superglue from drying out.
                          Awesome tip from this guy. I saw this a couple months ago and tried it and so far no dried out tubes. so i guess it works as he described it.
                          see the video.
                          • skookumchuck
                            • Feb 2012
                            • 62
                            Re: instant plastic
                            I tried this years ago and it didn't work.
                            • subaro
                              • Oct 2010
                              • 1274
                              Re: instant plastic
                              Here is one for you to try. cost you nothing to try, no money, just foil you have at home.
                              seems what they are saying is moisture seeps through the plastic head and into the tube. I do not know if this works, but sure is going to try it, as i have all kind of stuff that i hate the suprise of no good when opened.
