FRANCOTYP-POSTALIA-FP-5Li-SCALE
  • Geo
    • 662
    Hi
    Can someone please provide the power transformer specifications for the FP-5L postal scale ..Output voltage and parity...Can't find the transformer or specifications online.
  • guitar9199
    • Sep 2016
    • 1100
    Re: FRANCOTYP-POSTALIA-FP-5Li-SCALE
    Originally posted by Geo
    Hi
    120 VAC- 60 Hz
    Max 300mA
    ...that's from the operator's manual under Tech Specs. Nothing about the polarity though...likely ground sleeve/hot pin? You might need to call FP Dealer Line for this one.
    Good luck.
      Hi
      that is not considered a "dealer repair" so you will not find the specs.
        Originally posted by guitar9199
        120 VAC- 60 Hz
        Max 300mA
        Good luck.
        as an authorized dealer/service center, I can't get anything BUT calibration and setup manuals for any FP scale. and UNLESS someone has pirated the manual you won't find ANY FP manual online.
        • Geo
          • 662
          Yep..
          What you posted is all I could find , the scale doen't have the power requirements like most is not all other products. VERY strange.
          I even went online looking for a replacement transformer without any luck.
          Thanks...
