Martin Yale 1217 Folder
  • Scottb
    • Apr 2013
    • 312
    Has Martin Yale changed the feed roller design. I ordered a roller and what I got in isnt the same as what the folder has on it. I got a roller that has a allen set screw on the hub and what I got is a tension spring on the shaft that is screwed to the roller hub.
    Thanks for the info in advance.
    Scott
  • Iowatech
    Not a service manager
    • 3930
    Re: Martin Yale 1217 Folder
    Martin Yale is not the manufacturer of the folders I work on, so what follows is probably useless nonsense.
    Still, assuming that you are working on a model 1217A, I downloaded a parts list from here:
    Downloads & Support
    and found that the part number for the "feed wheel" (page 2, item 53) is W-A1217010. Is that the part number you used when ordering?
    Sorry if that was a waste of time.
