Print From Macbook
  • didi2005
    • May 2011
    • 401
    Print From Macbook
    There is 1 Macbook Pro running MacOSX 10.7, TOSHIBA_ColorMFP_X7 printer driver, network print to e3555c at office without problem.
    But after the client take the Macbook back home and print using his own Canon USB printer, the toshiba driver no longer working where I need to remove the existing driver and add back...
    Only this particular Macbook having this issue, whereby other Macbook/Macbook Air no such issue...
    Will it be the Canon USB printer conflict with the Toshiba driver?
    Is there anyway I can check from the Macbook?
  • MrForeSquare
    Re: Print From Macbook
    Update the MacBook to at least OSX 10.8.5 and then install the updated driver. Reboot and this should see you right. I have seen this happen a couple of times and this seemed to resolve the issue.
