Hello,
There is a problem with the shared PS Driver, installed on a Win 2012 Server.
If i add the shared driver on a client, I can't checkmark the watermark function of the driver, it remains grey.
Driver dialog says it can't be used under this configuration. I can use the watermark function on the 2012 server itself!
If I install the PS driver (newest version 5.1.2.0 is used, older version had the same problem) locally on the client, it works.
So the problem must have something to do with the printer sharing itself of the 2012 server.
There is no problem with the shared PCL driver too, watermark function can be used on the client.
I've tested the same PS driver on a Win 2008 R2 Server and a Win7 64bit client, there is no problem too.
Someone told me that this is a microsoft related problem and you can change something in the registry of
the 2012 server to solve it, but had no further information for me.
Can someone help me?
Thank you
Thank you
